[GRASS-stats] rgrass7 is not loading
Helmut Kudrnovsky
hellik at web.de
Tue Oct 4 11:36:44 PDT 2016
[you have to be subscribed to post in this ML]
benhemingway wrote
> I am having the same problem.
> Windows 10 Home 64 bit. Native GRASS 7.0.4 R 3.3.1
> When I try to load the rgrass7 library from within GRASS i get:
> Error : .onAttach failed in attachNamespace() for 'rgrass7', details:
> call: if (class(t0) != "try-error" && is.character(t0) && nchar(t0) >
> error: missing value where TRUE/FALSE needed
> Error: package or namespace load failed for 'rgrass7'
> When I try and load it from within R i get:
> Loading required package: sp
> Loading required package: XML
> GRASS GIS interface loaded with GRASS version: (GRASS not running)
> -Ben
after starting R in winGRASS and before library("rgrass7") , could you do:
sessionInfo()
have you installed any GRASS addons? if yes, which one?
the addons are installed in C:\Users\yourusername\AppData\Roaming\GRASS7
if you have installed some GRASS addons, could you delete the addons folder
in the C:\Users\yourusername\AppData\Roaming\GRASS7
then restart winGRASS (without any addons installed) and R and try to do
library("rgrass7") again and report the results.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/rgrass7-is-not-loading-tp5286725p5289278.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats
