[GRASS-stats] getLocationProj - writeVECT projection check mismatch
Paulo van Breugel p.vanbreugel at gmail.com
Sun Aug 12 05:15:03 PDT 2018
Dear devs,
The function getLocationProj returns an spproj-compliant PROJ.4 string
of projection information (using internally /g.proj -jf/). However, when
writing a vector layer to the grass database using the writeVECT
function, it (expects the projection information in the format returned
by /g.proj -g/ (checking the code, this is because it uses v.in.ogr I
guess).
For example, if running R from within a grass session with the NC
location: I have a vector layer "klatifolia" in latlong which I project
it to match the projection of the NC location. Next, I write it to the
grass database using writeVECT:
proj <- getLocationProj()
KLnew <- spTransform(KL, proj)
writeVECT(SDF=KLnew[,c(1,2,5)], vname="KLatifolia", driver="SQLite")
This results in an error telling that the projection of dataset does not
appear to match current location.
        Location PROJ_INFO is:
        name: Lambert Conformal Conic
        proj: lcc
        datum: nad83
        a: 6378137.0
        es: 0.006694380022900787
        lat_1: 36.16666666666666
        lat_2: 34.33333333333334
        lat_0: 33.75
        lon_0: -79
        x_0: 609601.22
        y_0: 0
        no_defs: defined
        Dataset PROJ_INFO is:
        ellps: grs80
        proj: lcc
        lat_0: 33.75
        lon_0: -79
        x_0: 609601.22
        y_0: 0
        towgs84: 0,0,0,0,0,0,0
        no_defs: defined
        ERROR: datum
I can obviously run writeVECT with v.in.ogr_flags="o", but is there a
way that writeVECT can check against the spproj-compliant proj.4 string?
Or is this something that should be dealt with at the v.in.ogr side?
Best wishes,
Paulo
sessionInfo()
R version 3.4.4 (2018-03-15)
Platform: x86_64-pc-linux-gnu (64-bit)
Running under: Ubuntu 18.04.1 LTS
Matrix products: default
BLAS: /usr/lib/x86_64-linux-gnu/blas/libblas.so.3.7.1
LAPACK: /usr/lib/x86_64-linux-gnu/lapack/liblapack.so.3.7.1
locale:
  [1] LC_CTYPE=en_US.UTF-8       LC_NUMERIC=C LC_TIME=en_US.UTF-8
  [4] LC_COLLATE=en_US.UTF-8     LC_MONETARY=en_US.UTF-8
LC_MESSAGES=en_US.UTF-8
  [7] LC_PAPER=en_US.UTF-8       LC_NAME=C LC_ADDRESS=C
[10] LC_TELEPHONE=C             LC_MEASUREMENT=en_US.UTF-8
LC_IDENTIFICATION=C
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods base
other attached packages:
[1] ggplot2_3.0.0  mapr_0.4.0     raster_2.6-7   rgrass7_0.1-11
XML_3.98-1.12  maptools_0.9-3
[7] sp_1.3-1       rgbif_1.0.2
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20180812/e5860251/attachment.html>
More information about the grass-stats mailing list
