[GRASS-stats] getLocationProj - writeVECT projection check mismatch
Paulo van Breugel
p.vanbreugel at gmail.com
Sun Aug 12 06:43:12 PDT 2018
On 12-08-18 15:12, Roger Bivand wrote:
> On Sun, 12 Aug 2018, Paulo van Breugel wrote:
>> Dear devs,
>> The function getLocationProj returns an spproj-compliant PROJ.4
>> string of projection information (using internally /g.proj -jf/).
>> However, when writing a vector layer to the grass database using the
>> writeVECT function, it (expects the projection information in the
>> format returned by /g.proj -g/ (checking the code, this is because it
>> uses v.in.ogr I guess).
>> For example, if running R from within a grass session with the NC
>> location: I have a vector layer "klatifolia" in latlong which I
>> project it to match the projection of the NC location. Next, I write
>> it to the grass database using writeVECT:
>> proj <- getLocationProj()
>> KLnew <- spTransform(KL, proj)
>> writeVECT(SDF=KLnew[,c(1,2,5)], vname="KLatifolia", driver="SQLite")
>> This results in an error telling that the projection of dataset does
>> not appear to match current location.
>> Location PROJ_INFO is:
>> name: Lambert Conformal Conic
>> proj: lcc
>> datum: nad83
>> a: 6378137.0
>> es: 0.006694380022900787
>> lat_1: 36.16666666666666
>> lat_2: 34.33333333333334
>> lat_0: 33.75
>> lon_0: -79
>> x_0: 609601.22
>> y_0: 0
>> no_defs: defined
>> Dataset PROJ_INFO is:
>> ellps: grs80
>> proj: lcc
>> lat_0: 33.75
>> lon_0: -79
>> x_0: 609601.22
>> y_0: 0
>> towgs84: 0,0,0,0,0,0,0
>> no_defs: defined
>> ERROR: datum
>> I can obviously run writeVECT with v.in.ogr_flags="o", but is there a
>> way that writeVECT can check against the spproj-compliant proj.4
>> string? Or is this something that should be dealt with at the
>> v.in.ogr side?
> Short answer - after inspecting the two, and checking that they are
> the same, use v.in.ogr_flags="o".
> Long answer: the PROJ migration from 4.* to 5.* and further is
> shifting things everywhere, so handling in GRASS and sf/rgdal will
> also change. On the R side, we are waiting for the GDAL barn-raising
> project (writing C++ classes for PROJ) to complete before considering
> moving to the pipeline model and possible new representations.
> Roger
Hi Roger, thanks for the reply, all clear, I'll keep on using
v.in.ogr_flags="o".
>> Best wishes,
>> Paulo
>> sessionInfo()
>> R version 3.4.4 (2018-03-15)
>> Platform: x86_64-pc-linux-gnu (64-bit)
>> Running under: Ubuntu 18.04.1 LTS
>> Matrix products: default
>> BLAS: /usr/lib/x86_64-linux-gnu/blas/libblas.so.3.7.1
>> LAPACK: /usr/lib/x86_64-linux-gnu/lapack/liblapack.so.3.7.1
>> locale:
>> [1] LC_CTYPE=en_US.UTF-8 LC_NUMERIC=C LC_TIME=en_US.UTF-8
>> [4] LC_COLLATE=en_US.UTF-8 LC_MONETARY=en_US.UTF-8
>> LC_MESSAGES=en_US.UTF-8
>> [7] LC_PAPER=en_US.UTF-8 LC_NAME=C LC_ADDRESS=C
>> [10] LC_TELEPHONE=C LC_MEASUREMENT=en_US.UTF-8
>> LC_IDENTIFICATION=C
>> attached base packages:
>> [1] stats graphics grDevices utils datasets methods base
>> other attached packages:
>> [1] ggplot2_3.0.0 mapr_0.4.0 raster_2.6-7 rgrass7_0.1-11
>> XML_3.98-1.12 maptools_0.9-3
>> [7] sp_1.3-1 rgbif_1.0.2
More information about the grass-stats
