[GRASS-stats] error when trying to start GRASS from Rstudio in Windows
Helmut Kudrnovsky hellik at web.de
Sat Oct 27 08:31:51 PDT 2018
Veronica Andreo wrote
> Hi
> I taught a GRASS course last week and all students got the same error when
> trying to init GRASS from R or Rstudio (in all cases grass was installed
> through OSGeo4W installer).
> Here“s the command we used (paths must be adapted accordingly):
> initGRASS(gisBase = "C:/OSGeo4W64/apps/grass/grass-7.4.2RC2",
>           gisDbase = "C:/Users/RETA/Documents/grassdata",
>           location = "nc_spm_08_grass7",
>           mapset = "user1",
>           SG = "elevation")
> The pop-up error is a missing iconv.dll. See screenshot attached. I
> believe
> all locales were in Spanish as well as the laptop I am testing now. After
> many attempts to try to close the pop-up error, we got the following in
> the
> Rstudio console:
> Error in if (!compatible) { : argument is of length zeroIn addition:
> Warning messages:1: In system(paste("g.dirseps.exe -g",
> shQuote(Sys.getenv("GISRC"))),  :  running command 'g.dirseps.exe -g
> "junk"' had status 3092: In system(paste("g.dirseps.exe -g",
> shQuote(gisDbase)), intern = TRUE) :  running command 'g.dirseps.exe
> -g "C:/Users/RETA/Documents/grassdata"' had status 3093: In
> dir.create(loc_path) :  cannot create dir 'NA\nc_spm_08_grass7',
> reason 'No such file or directory'4: In dir.create(paste(loc_path,
> "PERMANENT", sep = "/")) :  cannot create dir
> 'NA\nc_spm_08_grass7\PERMANENT', reason 'No such file or directory'5:
> In dir.create(paste(loc_path, mapset, sep = "/")) :  cannot create dir
> 'NA\nc_spm_08_grass7\user1', reason 'No such file or directory'6: In
> system(paste("g.version", get("addEXE", envir = .GRASS_CACHE),  :
> running command 'g.version.exe' had status 309
> Is this grass or windows problem? I did not get this error in this same
> laptop a month ago when Roger fixed some other problems. Seems that
> something changed meanwhile.
tested here now with
System Info
GRASS version: 7.4.2
GRASS SVN revision: r73591
Build date: 2018-10-23
Build platform: x86_64-w64-mingw32
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
Platform: Windows-10-10.0.17134 (OSGeo4W)
 > sessionInfo()
R version 3.4.4 (2018-03-15)
Platform: x86_64-w64-mingw32/x64 (64-bit)
Running under: Windows 10 x64 (build 17134)
Matrix products: default
l
[1] LC_COLLATE=German_Austria.1252  LC_CTYPE=German_Austria.1252
LC_MONETARY=German_Austria.1252 LC_NUMERIC=C
LC_TIME=German_Austria.1252
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
other attached packages:
[1] rgrass7_0.1-10 XML_3.98-1.11  sp_1.3-1
loaded via a namespace (and not attached):
[1] compiler_3.4.4  grid_3.4.4      lattice_0.20-35
confirmed, also here a iconv.dll-issue (missing iconv.dll); and also
confirmed that it worked a month or so ago.
closer look at the error message and the used dependencies:
winGRASS 7.4.2 is now compiled against GDAL: 2.3.2 and PROJ.4: 5.2.0
when I tried a month or so ago, winGRASS was compiled against GDAL 2.0.X (or
similar) and PROJ.4 4.9. (or similar).
it seems there could be a dll mismatch between old and new dependencies
versions; hence the iconv.dll issue.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
More information about the grass-stats mailing list
