[GRASS-stats] Cannot read raster or vector maps from GRASS within R
Veronica Andreo
veroandreo at gmail.com
Wed Oct 23 05:31:57 PDT 2019
Hi
I'm trying to read raster and vector maps from GRASS (located in my
grassdata) into R as I used to do until last month, but I'm getting the
following error:
> library(rgrass7)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: GRASS 7.8.1dev (2019)
and location: nc_basic_spm_grass7
> use_sf()
> v <- readVECT(roadsmajor)
Error in doGRASS(cmd, flags = flags, ..., parameters = parameters, echoCmd
= echoCmd, :
object 'roadsmajor' not found
> execGRASS("g.list", parameters=list(type="vector"))
hospitals
nc_state
points_of_interest
railroads
roadsmajor <-- it is there
schools
I tested with grass76 and 78 in case it could be some python issue (76 is
python 2 and 78 is python 3), but I'm getting the same error with both
GRASS versions.
Has anything changed since september? This worked at the opengeohub summer
school.
I paste the session info below. Thanks in advance for any help :)
Vero
sessionInfo()
R version 3.6.1 (2019-07-05)
Platform: x86_64-redhat-linux-gnu (64-bit)
Running under: Fedora 30 (Thirty)
Matrix products: default
BLAS/LAPACK: /usr/lib64/R/lib/libRblas.so
locale:
[1] LC_CTYPE=en_US.UTF-8 LC_NUMERIC=C
[3] LC_TIME=en_US.UTF-8 LC_COLLATE=en_US.UTF-8
[5] LC_MONETARY=en_US.UTF-8 LC_MESSAGES=en_US.UTF-8
[7] LC_PAPER=en_US.UTF-8 LC_NAME=C
[9] LC_ADDRESS=C LC_TELEPHONE=C
[11] LC_MEASUREMENT=en_US.UTF-8 LC_IDENTIFICATION=C
attached base packages:
[1] stats graphics grDevices utils datasets methods base
other attached packages:
[1] rgrass7_0.2-1 XML_3.98-1.20
loaded via a namespace (and not attached):
[1] tidyselect_0.2.5 purrr_0.3.2 reshape2_1.4.3 sf_0.8-0
[5] splines_3.6.1 lattice_0.20-38 colorspace_1.4-1
generics_0.0.2
[9] stars_0.3-1 stats4_3.6.1 survival_2.44-1.1
prodlim_2018.04.18
[13] rlang_0.4.0 ModelMetrics_1.2.2 e1071_1.7-2 pillar_1.4.2
[17] glue_1.3.1 withr_2.1.2 DBI_1.0.0 foreach_1.4.7
[21] plyr_1.8.4 lava_1.6.6 stringr_1.4.0
timeDate_3043.102
[25] munsell_0.5.0 gtable_0.3.0 recipes_0.1.7
codetools_0.2-16
[29] caret_6.0-84 parallel_3.6.1 class_7.3-15 Rcpp_1.0.2
[33] KernSmooth_2.23-15 scales_1.0.0 classInt_0.4-1 ipred_0.9-9
[37] abind_1.4-5 ggplot2_3.2.1 stringi_1.4.3 dplyr_0.8.3
[41] grid_3.6.1 tools_3.6.1 magrittr_1.5
lazyeval_0.2.2
[45] tibble_2.1.3 crayon_1.3.4 pkgconfig_2.0.3 MASS_7.3-51.4
[49] Matrix_1.2-17 data.table_1.12.2 lubridate_1.7.4 gower_0.2.1
[53] assertthat_0.2.1 iterators_1.0.12 R6_2.4.0 rpart_4.1-15
[57] units_0.6-4 nnet_7.3-12 nlme_3.1-140
compiler_3.6.1
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20191023/b5724e9e/attachment.html>
More information about the grass-stats
