[GRASS-stats] Cannot read raster or vector maps from GRASS within R
Veronica Andreo
veroandreo at gmail.com
Wed Oct 23 05:45:10 PDT 2019
Thanks Roger!
I just tried that and was about to write again saying "dismiss my previous
email" but you were faster! :)
El mié., 23 oct. 2019 a las 14:36, Roger Bivand (<Roger.Bivand at nhh.no>)
escribió:
> On Wed, 23 Oct 2019, Veronica Andreo wrote:
> > Hi
> > I'm trying to read raster and vector maps from GRASS (located in my
> > grassdata) into R as I used to do until last month, but I'm getting the
> > following error:
> >> library(rgrass7)
> > Loading required package: XML
> > GRASS GIS interface loaded with GRASS version: GRASS 7.8.1dev (2019)
> > and location: nc_basic_spm_grass7
> >> use_sf()
> >> v <- readVECT(roadsmajor)
> > Error in doGRASS(cmd, flags = flags, ..., parameters = parameters,
> echoCmd
> > = echoCmd, :
> > object 'roadsmajor' not found
> v <- readVECT("roadsmajor")
> # maybe - it isn't an object in the R workspace
> Roger
> >> execGRASS("g.list", parameters=list(type="vector"))
> > hospitals
> > nc_state
> > points_of_interest
> > railroads
> > roadsmajor <-- it is there
> > schools
> > I tested with grass76 and 78 in case it could be some python issue (76 is
> > python 2 and 78 is python 3), but I'm getting the same error with both
> > GRASS versions.
> > Has anything changed since september? This worked at the opengeohub
> summer
> > school.
> > I paste the session info below. Thanks in advance for any help :)
> > Vero
> > sessionInfo()
> > R version 3.6.1 (2019-07-05)
> > Platform: x86_64-redhat-linux-gnu (64-bit)
> > Running under: Fedora 30 (Thirty)
> > Matrix products: default
> > BLAS/LAPACK: /usr/lib64/R/lib/libRblas.so
> > locale:
> > [1] LC_CTYPE=en_US.UTF-8 LC_NUMERIC=C
> > [3] LC_TIME=en_US.UTF-8 LC_COLLATE=en_US.UTF-8
> > [5] LC_MONETARY=en_US.UTF-8 LC_MESSAGES=en_US.UTF-8
> > [7] LC_PAPER=en_US.UTF-8 LC_NAME=C
> > [9] LC_ADDRESS=C LC_TELEPHONE=C
> > [11] LC_MEASUREMENT=en_US.UTF-8 LC_IDENTIFICATION=C
> > attached base packages:
> > [1] stats graphics grDevices utils datasets methods base
> > other attached packages:
> > [1] rgrass7_0.2-1 XML_3.98-1.20
> > loaded via a namespace (and not attached):
> > [1] tidyselect_0.2.5 purrr_0.3.2 reshape2_1.4.3 sf_0.8-0
> > [5] splines_3.6.1 lattice_0.20-38 colorspace_1.4-1
> > generics_0.0.2
> > [9] stars_0.3-1 stats4_3.6.1 survival_2.44-1.1
> > prodlim_2018.04.18
> > [13] rlang_0.4.0 ModelMetrics_1.2.2 e1071_1.7-2
> pillar_1.4.2
> > [17] glue_1.3.1 withr_2.1.2 DBI_1.0.0
> foreach_1.4.7
> > [21] plyr_1.8.4 lava_1.6.6 stringr_1.4.0
> > timeDate_3043.102
> > [25] munsell_0.5.0 gtable_0.3.0 recipes_0.1.7
> > codetools_0.2-16
> > [29] caret_6.0-84 parallel_3.6.1 class_7.3-15 Rcpp_1.0.2
> > [33] KernSmooth_2.23-15 scales_1.0.0 classInt_0.4-1 ipred_0.9-9
> > [37] abind_1.4-5 ggplot2_3.2.1 stringi_1.4.3 dplyr_0.8.3
> > [41] grid_3.6.1 tools_3.6.1 magrittr_1.5
> > lazyeval_0.2.2
> > [45] tibble_2.1.3 crayon_1.3.4 pkgconfig_2.0.3
> MASS_7.3-51.4
> > [49] Matrix_1.2-17 data.table_1.12.2 lubridate_1.7.4 gower_0.2.1
> > [53] assertthat_0.2.1 iterators_1.0.12 R6_2.4.0
> rpart_4.1-15
> > [57] units_0.6-4 nnet_7.3-12 nlme_3.1-140
> > compiler_3.6.1
> Roger Bivand
> Department of Economics, Norwegian School of Economics,
> Helleveien 30, N-5045 Bergen, Norway.
> voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
> https://orcid.org/0000-0003-2392-6140
> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20191023/696e7202/attachment.html>
More information about the grass-stats
