[GRASS-stats] Package rgrass7 - g.extension function
Roger Bivand
Roger.Bivand at nhh.no
Wed May 6 03:48:53 PDT 2020
On Tue, 5 May 2020, Helmut Kudrnovsky wrote:
> romain Fer. wrote
>> Hello,
>> I am a french student in master's degrees, in advence I'm sorry for my
>> english.
>> I using the package rgrass7 with R during my internship and I have a error
>> on one function of this package. I use g.extension to import r.clip. I
>> explain this error on this forum :
>> https://gis.stackexchange.com/questions/360310/install-grass-extension-with-g-extension-and-rstudio
>> Can you look my explications of this problem and do you give me your
>> opinion on this error ?
>> Thanks you in advance for your help,
> there are maybe several issues here:
>> initGRASS("C:/Program Files/GRASS GIS 7.6"
> is it possible to upgrade to the 7.8.x-line?
>> libgis_revison = grass.version()['libgis_revision']
>> KeyError: 'libgis_revision'
> AFAIR there have been some issues with libgis_revision in earlier versions;
> this should be addressed in 7.8.x-line.
>> ATTENTION: GRASS_ADDON_BASE is not defined
> this variable should be defined that the addon is installed in the correst
> place.
> when you use winGRASS out of RStudio, are there all needed variables
> defined?
Exactly, because RStudio uses multiple layers of processes, often the
processes do not inherit environments properly. Do use Rgui on Windows,
not Rstudio. If the error repeats with Rgui, then we know more.
How was GRASS installed, via OSGeo4W or winGRASS?
Roger
> see
> https://github.com/OSGeo/grass/blob/master/mswindows/env.bat
> for hints which variables should be defined in minimum that standalone
> winGRASS is working.
> %GISBASE% is the installation path to standalone winGRASS.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the grass-stats
