[GRASS-stats] [GRASS-user] Running r-grass examples when building a R package
Bernardo Santos bernardo_brandaum at yahoo.com.br
Tue Aug 30 04:18:44 PDT 2022
 Hi Stefan,(and thanks Roger and Floris for replying as well)
Your solution worked perfectly, Stefan. Thanks a lot!In the case of continuous integration within Github as it is the case, it seems we must ask GRASS to be installed in the virtual machine.
This could be done with Stefan's suggestion, adding these lines to the yaml file within .github/workflows:
- name: Install GRASS GIS and other dependencies        run: |          sudo apt-get update -qq          sudo apt-get install -y -qq grass grass-dev grass-doc wget
You can also see it here: Install GRASS for CI by ninsbl · Pull Request #11 · NINAnor/oneimpact (github.com)
I guess this could be documented for GRASS/R users somewhere? Maybe in some wiki?Any suggestion on where to add this?
BestBernardo
    Em sexta-feira, 26 de agosto de 2022 13:27:46 GMT+2, Stefan Blumentrath <stefan.blumentrath at nina.no> escreveu:
  <!--#yiv0852532148 _filtered {} _filtered {} _filtered {} _filtered {}#yiv0852532148 #yiv0852532148 p.yiv0852532148MsoNormal, #yiv0852532148 li.yiv0852532148MsoNormal, #yiv0852532148 div.yiv0852532148MsoNormal {margin:0cm;font-size:11.0pt;font-family:"Calibri", sans-serif;}#yiv0852532148 a:link, #yiv0852532148 span.yiv0852532148MsoHyperlink {color:blue;text-decoration:underline;}#yiv0852532148 pre {margin:0cm;margin-bottom:.0001pt;font-size:10.0pt;font-family:"Courier New";}#yiv0852532148 span.yiv0852532148HTMLPreformattedChar {font-family:Consolas;}#yiv0852532148 span.yiv0852532148ydpa6a6511er-in {}#yiv0852532148 span.yiv0852532148ydpa6a6511efu {}#yiv0852532148 span.yiv0852532148ydpa6a6511eop {}#yiv0852532148 span.yiv0852532148ydpa6a6511est {}#yiv0852532148 span.yiv0852532148ydpa6a6511ecn {}#yiv0852532148 span.yiv0852532148EmailStyle26 {font-family:"Calibri", sans-serif;color:windowtext;}#yiv0852532148 .yiv0852532148MsoChpDefault {font-size:10.0pt;} _filtered {}#yiv0852532148 div.yiv0852532148WordSection1 {}-->
Hi Bernardo,
Seems like GRASS GIS isn`t installed on the CI VM.
Please see:
https://github.com/NINAnor/oneimpact/pulls
You may add UbuntuGIS PPAs if you want other versions than shipped by plain Ubuntu.
Cheers
Stefan
From: grass-user <grass-user-bounces at lists.osgeo.org>On Behalf Of Bernardo Santos via grass-user
Sent: fredag 26. august 2022 12:56
To: grass-stats at lists.osgeo.org; GRASS User List <grass-user at lists.osgeo.org>
Subject: [GRASS-user] Running r-grass examples when building a R package
Dear all,
I am building a R package and some of the functions use rgrass to connect to a GRASS project and run thingfs within GRASS.
I have now set up a webpage for the package using pkgdown in integrated to Github actions. This means when I push new commits all the examples of R functions are run again and the webpage is updated with the results of the examples. Here is the webpage: https://ninanor.github.io/oneimpact/
All works fine, except the functions calling GRASS. When I run the examples form my local computer everything works, but in the Github actions it does not run, apparently because the command
 system("grass78 --config path", intern = T)
to find the GRASS folder and use within rgrass::initGRASS does not work, so the connection between R and GRASS do not exist.
Does someone in the group has experience with that and could help with hints to solve it?
Is there a recommended way to make sure Github actions know where GRASS is and use it?
Best
Bernardo
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20220830/c68bd036/attachment.htm>
More information about the grass-stats mailing list
