[GRASS-translations] incorrect refs?
Maxim Dubinin
sim at gis-lab.info
Sat Aug 2 14:45:18 EDT 2008
Thanks, Martin.
I'm afraid no one has experience in dealing with po-files besides
translation itself (which we do with poedit).
Practically, did I understand right, that these incorrect messages are not a big
deal and can be fixed later after the translation by updating?
Best regards,
Maxim mailto:sim at gis-lab.info
http://gis-lab.info
Вы писали 2 августа 2008 г., 13:06:00:
ML> Hi,
ML> 2008/8/2 Maxim Dubinin <sim at gis-lab.info>:
>> It seems that some of the references to the code are incorrect, here
>> is an example from grassmods_ru.po:
>>> #: ../raster/r.cost/main.c:275 ../raster/r.walk/main.c:392
>>> msgid "Input null cell will be retained into output map"
>>> msgstr ""
>> If I look this code up in grass-6.3.0, first ref is this:
>>>G_fatal_error(_("No start points"));
>> and second is a blank line. I.e. links are wrong?
ML> take a look at locale/README file.
ML> In locale directory run first
ML> make pot
ML> make update-po
ML> to update PO files.
ML> Good luck, мартин
More information about the grass-translations
