[GRASS-translations] modules translation and description.html
Markus Neteler neteler at osgeo.org
Thu Dec 18 06:04:02 EST 2008
Hi Maxim,
On Tue, Dec 16, 2008 at 10:51 PM, Maxim Dubinin <sim at gis-lab.info> wrote:
> Hi all,
> we've started looking into translating individual docs for modules,
> but found some inconsistency between html version from the website and
> description.html from some of the modules.
Note that description.html in the source code is used to *construct*
the final HTML version (this happens when the source code is
compiled).
> Take d.colorlist for example as html:
> http://grass.osgeo.org/grass64/manuals/html64_user/d.colorlist.html
> and compare with description.html for this command from either 6.3 or
> 6.4. For some reason description.html from neither 6.3 or 6.4 contains
> some parts such as NAME, SYNOPSIS etc. I assume these parts are added
> automatically, is it so?
Exactly.
Each module, using --html-description flag, generates the HTML template
which is then combined with the content of description.html.
> Can someone explain what is going on with them and how
> description.html should really look like? Based on what is in /doc for
> sample module page, the description.html should start from
> DESCRIPTION, is it so?
description.html contains the real descriptive content without parameters,
flags etc.
For translations, description.html is relevant. Not the web page.
Hope it is clear now.
Markus
More information about the grass-translations mailing list
