[GRASS-dev] Re: [GRASS-translations] UTF-8 or ISO?
Wed Mar 12 01:40:53 EDT 2008
Martin Landa wrote:
> >  I am newbie in translations and my question probably is simple one.
> >  Which *.po files coding standard is recommended now?
> >  UTF or ISO?
> >  I continue polish translation (i.e. UTF-8 and ISO-8859-2).
> I guess ISO(?)
I think so. If your system supports UTF-8, it will support converting
ISO-8859-2 to UTF-8. OTOH, if your system has negligible I18N support,
you'll have problems if the files are in UTF-8.
Also, using ISO-8859-* encodings helps to discourage people from
gratuitous use of features such as "enhanced" punctuation.
More information about the grass-translations mailing list
