[GRASS-translations] Transifex manager wanted for GRASS GIS!
Luca Delucchi
lucadeluge at gmail.com
Tue Feb 14 23:55:06 PST 2017
On 14 February 2017 at 17:36, Maris Nartiss <maris.gis at gmail.com> wrote:
> I'm sorry Luca, you are wrong. My example is perfectly valid Gettext
> and can be found also in Gettext documentation as an example. If
> Transifex can not handle it, it is bug in Transifex. When introducing
> plural form support in GRASS GIS, I was carefully following Gettext
> documentation.
ok, could you want to be added as Transifex manager?
> Still grasslibs_ko seems to be incomplete - it lacks Plural-Forms:
> definition in its header. It has caused an issue that PO file is wrong
> - Korean has only one plural form but PO file provides two.
> To fix the issue is necessary to: never mind. Done in r70564.
I tested the new version and I was able to import grassmods_ko but not
grasslibs_ko...
> Try again.
> Māris.
ciao
Luca
www.lucadelu.org
More information about the grass-translations
