[GRASS-translations] Transifex manager wanted for GRASS GIS!
Huidae Cho
grass4u at gmail.com
Wed Feb 22 03:16:49 PST 2017
Also, can I use both svn and transifex? Will there be any conflicts between
them?
Thanks.
On Wed, Feb 22, 2017 at 6:11 AM, Huidae Cho <grass4u at gmail.com> wrote:
> I see the Upload file button. What happens if I upload a file when there
> are translations? Overwriting or adding?
> Thanks.
> On Wed, Feb 15, 2017 at 2:57 AM, Luca Delucchi <lucadeluge at gmail.com>
> wrote:
>> On 14 February 2017 at 19:55, Huidae Cho <grass4u at gmail.com> wrote:
>> > I'll check the files. Do I have the rights to upload the po files to
>> > transifex?
>> I don't know, could you check?
>> When you select a "resource" to translate, in the popup you should see
>> "Upload file"
>> ciao
>> Luca
>> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-translations/attachments/20170222/dbdb5a6c/attachment-0001.html>
More information about the grass-translations
