[GRASS-translations] Fwd: [OSGeo-Discuss] Help us test out Weblate
Markus Neteler
neteler at osgeo.org
Fri Jan 7 02:00:08 PST 2022
Dear translators,
For the time being our translations have been managed via
https://www.transifex.com/grass-gis/
FYI, OSGeo is now hosting an open source solution for message translations:
https://weblate.osgeo.org/
Just in case one day we want to migrate :-)
See also below.
Best,
Markus
---------- Forwarded message ---------
From: Regina Obe via Discuss <discuss at lists.osgeo.org>
Date: Fri, Jan 7, 2022 at 12:47 AM
Subject: [OSGeo-Discuss] Help us test out Weblate
To: <discuss at lists.osgeo.org>
Cc: PostGIS Users Discussion <postgis-users at lists.osgeo.org>,
pgRouting developers mailing list <pgrouting-dev at lists.osgeo.org>
We have Weblate installed on OSGeo infra
At
For a trial run I'm using our PostGIS workshop
You can login with your LDAP credentials and then I can grant you rights to
the postgis-workshop project.
If I set this up right - commits should show up after an hour or so after
each commit on the below links.
English: https://postgis.net/workshops/en/postgis-intro/
Japanese: https://postgis.net/workshops/ja/postgis-intro/
German: https://postgis.net/workshops/de/postgis-intro/
Spanish: https://postgis.net/workshops/es/postgis-intro/
Italian: https://postgis.net/workshops/it/postgis-intro/
And you should see your commit show here:
https://github.com/postgis/postgis-workshops
here is an example Sandro did -
https://github.com/postgis/postgis-workshops/commit/f3b1f810a9c25d2889c2216b
62d4843a44544858
My plan is after we are done with some kicking of tires, we will switch
PostGIS docs from transifex to weblate.
For others who want to try it on their projects, let me know I can show you
what little I know about the topic :)
Thanks,
Regina
Discuss mailing list
Discuss at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/discuss
More information about the grass-translations
