[GRASS-translations] Fwd: [OSGeo-Discuss] Help us test out Weblate
Huidae Cho grass4u at gmail.com
Thu Mar 17 16:54:00 PDT 2022
Markus,
Did you have a chance to try it? I can log in, but I don't have a
permission to create a new project.
Best,
Huidae
On Thu, Feb 17, 2022 at 1:38 PM Regina Obe <lr at pcorp.us> wrote:
> Markus,
> Can you log into weblate.osgeo.org with your OSGeo account.
> Once you log in I can give you Admin rights and then you can setup any
> projects you need.
> For github integration if you want to use the pull request model, you will
> need to setup the project as Github instead of git.
> Pull requests will come from osgeoweblate github account.
> Here is an example of what one looks like:
> https://github.com/postgis/postgis-workshops/pull/41
> If you need help pulling over the files let me know.
> The tricky part is you have to setup Component Discovery to have the files
> pull over and continue to update.
> Thanks,
> Regina
> > -----Original Message-----
> > From: Markus Neteler [mailto:neteler at osgeo.org]
> > Sent: Thursday, February 17, 2022 2:40 AM
> > To: Regina Obe <lr at pcorp.us>
> > Cc: GRASS translations <grass-translations at lists.osgeo.org>; Huidae Cho
> > <grass4u at gmail.com>
> > Subject: Re: [GRASS-translations] Fwd: [OSGeo-Discuss] Help us test out
> > Weblate
> > Hi Regina,
> > The GRASS GIS project would be interested to try out Weblate.
> > What needs to be done for this?
> > Thanks,
> > Markus
> > On Wed, Feb 16, 2022 at 11:04 PM Huidae Cho <grass4u at gmail.com> wrote:
> > > Markus,
> > > Weblate looks promising. Can we *try* it?
> > > Best,
> > > Huidae
> > > Huidae Cho, Ph.D., GISP, /hid? t??o/, ???, ???
> > > GRASS GIS Developer
> > > https://idea.isnew.info/
> > > On Fri, Jan 7, 2022 at 5:00 AM Markus Neteler <neteler at osgeo.org>
> wrote:
> > >> Dear translators,
> > >> For the time being our translations have been managed via
> > >> https://www.transifex.com/grass-gis/
> > >> FYI, OSGeo is now hosting an open source solution for message
> > translations:
> > >> https://weblate.osgeo.org/
> > >> Just in case one day we want to migrate :-)
> > >> See also below.
> > >> Best,
> > >> Markus
> > >> ---------- Forwarded message ---------
> > >> From: Regina Obe via Discuss <discuss at lists.osgeo.org>
> > >> Date: Fri, Jan 7, 2022 at 12:47 AM
> > >> Subject: [OSGeo-Discuss] Help us test out Weblate
> > >> To: <discuss at lists.osgeo.org>
> > >> Cc: PostGIS Users Discussion <postgis-users at lists.osgeo.org>,
> > >> pgRouting developers mailing list <pgrouting-dev at lists.osgeo.org>
> > >> We have Weblate installed on OSGeo infra
> > >> At
> > >> For a trial run I'm using our PostGIS workshop
> > >> You can login with your LDAP credentials and then I can grant you
> > >> rights to the postgis-workshop project.
> > >> If I set this up right - commits should show up after an hour or so
> > >> after each commit on the below links.
> > >> English: https://postgis.net/workshops/en/postgis-intro/
> > >> Japanese:  https://postgis.net/workshops/ja/postgis-intro/
> > >> German: https://postgis.net/workshops/de/postgis-intro/
> > >> Spanish: https://postgis.net/workshops/es/postgis-intro/
> > >> Italian: https://postgis.net/workshops/it/postgis-intro/
> > >> And you should see your commit show here:
> > >> here is an example Sandro did -
> > workshops/commit/f3b1f810a9c25d288
> > >> 9c2216b
> > >> 62d4843a44544858
> > >> My plan is after we are done with some kicking of tires, we will
> > >> switch PostGIS docs from transifex to weblate.
> > >> For others who want to try it on their projects, let me know I can
> > >> show you what little I know about the topic :)
> > >> Thanks,
> > >> Regina
> > >> _______________________________________________
> > >> Discuss mailing list
> > >> Discuss at lists.osgeo.org
> > >> https://lists.osgeo.org/mailman/listinfo/discuss
> > >> grass-translations mailing list
> > >> https://lists.osgeo.org/mailman/listinfo/grass-translations
Huidae Cho, Ph.D., GISP, /hidɛ <http://ipa-reader.xyz/?text=hid%C9%9B>
t͡ɕo/, 조희대, 曺喜大
GRASS GIS Developer
URL: <http://lists.osgeo.org/pipermail/grass-translations/attachments/20220317/fbffaad7/attachment-0001.html>
More information about the grass-translations mailing list
