DXF input with heights
Chaitanya S. Rajguru
rajguruc at vttcf.cc.vt.edu
Fri Apr 17 15:13:51 EDT 1992
Hi, Jan,
> 1. Does anyone have a newer v.in.dxf program that will accept and store
> elevation values for later use.?
I have gone thru' the same problem; getting DXF data with associated
heights into GRASS. I implemented a specific solution to this:
The DXF file is allowed to contain only line and area info. The height
is stored as text in the middle of an area line/polyline. My program
reads in this text and stores it as an attribute for the area edge
in the imported vector file. Then another program (that uses
r.mapcalc) computes a raster file after a v.to.rast , and offsetd
the corresponding areas vertically to the heights given by their
attributes.
I am also thinking of importing 3DLINE data.
If you would like to know more, or if something is not clear,
do write to me.
Good luck.
-Raj
__________________________________________________________________
Mobile And Portable Radio rajguruc at vttcf.cc.vt.edu
Research Group raj at mprg1.mprg.ee.vt.edu
Dept. of Electrical Engg. (703) 231-4160
VPI&SU (Virginia Tech)
