questions on m.examine.tape and i.tape.other to run on a file!
    Laxmi Prasad Musunur
    mlp at forestry.auburn.edu
    Fri Aug 21 11:41:57 EDT 1992
	We were trying to run m.examine.tape on a file. It asked for the size of
buffer. Depending on the size of buffer no. of rows and columns keep changing.
So, what is the best way to do this?
Size of the TM image file is :  99140608
If we run m.examine.tape on this file using a buffer size of 32767
len  :  records
32767:  1-3025
20437:3026-3026
Using size of buffer: 40000
m.examine.tape gives
len   : records
40000 : 1-2478
20608 : 2479-2479
	To extract the same TM image:
	While running i.tape.other if we select BSQ format (and all bands are in a single file)
is it CORRECT to give
3026  for total number of records
32767 for the length of the longest record
	What should I enter for the end row and end column for selecting the window
to extract ?
	Do I make any sense ?
	Appreciate your help.
	Laxmi P. Musunur (LP)
