HELP!! Clark66->WGS84 ???#%@*!
Phil Chaney phil at spock.uark.edu
Thu Aug 27 10:44:27 EDT 1992
> Date sent:  26-AUG-1992 10:11:28
> Hi Michael and others:
> >It isn't quite so simple.
> It figures!!
> >Recent quad sheets have approximate datum shifts for the  corners
> >of  the  map and perhaps can be used to devise a linear shift for
> >the entire map.
> What about m.datum.shift? can I shift the corners of the bounding area
> of the data to find a linear shift to be appied to each site falling
> within the area? This is the method I had planned to use but I didn't
> understand what the dx,dy,dz parameters should be set to, Any help here?
> Thanks,
> Gerry Hatcher
> Ocean Mapping Development Center|      gerry at omdc.gso.uri.edu {Internet}
> University of Rhode Island      |            cbeam::gerry {span}
> voice (401)-792-6940            |            fax (401)-792-6849
Gerry,
   It looks like you need to pursue help from NGS, or some local
organization that may have some GPS software that could do the
transformations for you. A good source of help in your area would
be the Surveying and Engineering Dept. at the University of Maine!
Good Luck,
Phillip L. Chaney       Center for Advanced Spatial Technologies
Research Specialist     National Center for Resource Innovations-SW
                        12 Ozark Hall
       N                University of Arkansas
       |                Fayetteville, Arkansas 72701
    W -+- E             Phone: (501) 575-6159
       |                       (501) 575-4575
       S                FAX:   (501) 575-3846
                        E-mail: phil at spock.uark.edu
