erdas images into Grass4.0
danR at rsgis3.tamu.edu danR at rsgis3.tamu.edu
Fri Aug 28 15:39:32 EDT 1992
Recently I tried to import a *.GIS file into r.in.erdas and the following
problem occurred.
OPTION:   input erdas trailer file name
     key: trl
required: NO
enter option > /usr6/local4/vernon/vernonst/imagery/517.trl
You have chosen:
  trl=/usr6/local4/vernon/vernonst/imagery/517.trl
Is this correct? (y/n) [y] y
OPTION:   Prefix of the GRASS raster files to be created.
     key: prefix
required: YES
enter option > test
You have chosen:
  prefix=test
HEAD74
pack type------ 0
number bands----------- 256
number cols,rows------- -519700480, -1123811328
starting coordinate --- 16777216, 16777216
map type -------------- 256
number classes -------- 7936
area ------------------ 0.000000 N
map coordinate -------- -0.000000, 0.000000
pixel size ------------ 0.000000, 0.000000
Error in memory allocation
is this a problem with  the *.GIS header file of file location.
Thank you.
					Daniel H. Rodriguez
