Volume Calculation of Area for Reservoir Analysis using Grass
Simon Cox
simon at cerberus.earth.monash.edu.au
Thu Dec 3 14:35:23 EST 1992
I think you could replace steps 5-9 with a simple awk program.
But anyway, ain't grass+unix tools wonderful!
Simon Cox
> Yes, GRAASS can be used to do volumetric calculations. There is no
> straightforward program, but the following outline will start you
> in the right direction:
> 1) Use the screen-oriented digitizing capability to outline the anticipated
> extent of the area for which a volume will be calculated.
> 2) Use the masking program to mask into this area
> 3) Subtract the DEM values from the fill height value using r.mapcalc
> 4) Run r.stats on the results
> You now have something like:
> -1 1357
> 1 3456
> 2 1234
> (The first value is the delta h (height), the second the area)
> 5) Filter out negative values (areas where the DEM height is greater than
> the fill height). (Use sed(1))
> 1 3456
> 2 1234
> 6) Turn the output into a bc(1) input script where the height values are
> multiplied by their corresponding area values.
> 1 * 3456
> 2 * 1234
> 7) Send the result through bc(1)
> 3456
> 2468
> 8) Sum these values; add the appropriate dc(1) commands:
> 3456
> 2468 +
> p
> 9) Send through dc(1) for your final volume
__________________________________________________________________
Dr Simon Cox
__ L
,~' L_|\ Department of Earth Sciences
,-' \ Monash University
( \ Clayton Vic 3168 Australia
\ ___ /
L,~' "\_x/ Phone +61 3 565 5762
u Fax +61 3 565 5062
