v.in.arc
GHATCHER GERRY at omdc.gso.uri.edu
Tue Jan 14 08:58:00 EST 1992
Date sent:  14-JAN-1992 08:53:15
>I am having trouble using the v.in.arc command. The error message
>"cannot find ARC-INFO lines file" is displayed.  I have tried
>putting the lines and points files from the ARC 'ungenerate'
>command in several different directories.  Is there a specific
>file naming convention for these files different than adding a
>.lin and a .pts after the filename?
>Jim Klein 804-924-6438
Use the v.out.arc command and see where it creates the file,
I believe its in $MAPSET/arc . Try putting your "ungenerated"
files there.
Good luck;
Gerry Hatcher
Ocean Mapping Development Center|      Gerry at omdc.gso.uri.edu {Internet}
University of Rhode Island      |
(401)-792-6940                  |              cbeam::gerry {span}
