GRASS on Linux
Michael Shapiro shapiro at zorro.cecer.army.mil
Wed Jul 22 17:34:33 EDT 1992
|/grass/src/imagery/i.class would not compile correctly. The following
|error occurs:
|	zoom_box.c: In function 'zoom1'
|	zoom_box.c:34: 'cancel' undeclared (first use this function)
|			each undeclared identifier is reported only once for
|			each function it appears in.
|	zoom_box.c: At top level
|	zoom_box.c:183: 'cancel' used prior to declaration
The problem is that the functions cancel(), zoom1() were not declared
prior to use in parts of the code. Here is a fixed zoom_box.c that should
compile.
#include "globals.h"
static int x1, y1, x2, y2;
static View *pick_view, *zoom_view, *main_view;
static int cancel();
static int zoom1();
static int zoom2();
zoom_box()
    static int use = 1;
    static Objects objects[]=
	MENU("Cancel",cancel,&use),
	INFO(" Mark first corner of window ",&use),
	OTHER(zoom1,&use),
	{0}
    pick_view = zoom_view = main_view = NULL;
    Input_pointer (objects);
    return 0;
static
zoom1(x,y,b)	/* called by Input_pointer */
    static int use = 1;
    static Objects objects[] =
	INFO(" Define the window ",&use),
	OTHER(zoom2,&use),
	{0}
 * user has marked first corner
 * this determines which view is being zoomed
/*fprintf(stderr,"\nX, Y, B in zoom1 %d %d %d", x,y,b); */
    x1 = x;
    y1 = y;
    if (In_view (pick_view = VIEW_MAP1, x1, y1))
	main_view = VIEW_MAP1;
	zoom_view = VIEW_MAP1_ZOOM;
    else if (In_view (pick_view = VIEW_MAP1_ZOOM, x1, y1))
	if (!pick_view->cell.configured)
	    return 0;	/* ignore the mouse event */
    else
    if (!pick_view->cell.configured) return 0;	/* just to be sure */
    return Input_box (objects, x, y);
static
zoom2 (x, y, b)
    int top, bottom, left, right;
    int row,col;
    struct Cell_head cellhd;
/*fprintf(stderr,"\nX, Y, B in zoom2 %d %d %d", x,y,b);*/
    x2 = x;
    y2 = y;
 * user has completed the zoom window.
 * must be in same view as first corner
    if (x1 == x2 || y1 == y2) return 0;	/* ignore event */
    if (!In_view (pick_view,x2,y2)) return 0;
 * ok, erase menu messages
    Menu_msg("");
 * assign window coordinates to top,bottom,left,right
    if (x1 < x2)
	left = x1;
	right = x2;
    else
	left = x2;
	right = x1;
    if (y1 < y2)
	top = y1;
	bottom = y2;
    else
	top = y2;
	bottom = y1;
/*fprintf(stderr,"\nleft right top bottom %d %d %d %d", left,right,top,bottom);*/
 * Determine the the zoom window (ie, cellhd)
 * must copy the current view cellhd first, to preserve header info
 * (such as projection, zone, and other items.)
 * compute zoom window northings,eastings, rows, cols, and resolution
    G_copy (&cellhd, &pick_view->cell.head, sizeof(cellhd));
/* convert top to northing at top edge of cell
 * left to easting at left edge
    col = view_to_col(pick_view,left);
    row = view_to_row(pick_view,top);
    cellhd.north = row_to_northing (&pick_view->cell.head,row,0.0);
    cellhd.west  = col_to_easting  (&pick_view->cell.head,col,0.0);
/* convert bottom to northing at bottom edge of cell
 * right to easting at right edge
    col = view_to_col(pick_view,right);
    row = view_to_row(pick_view,bottom);
    cellhd.south = row_to_northing (&pick_view->cell.head,row,1.0);
    cellhd.east  = col_to_easting  (&pick_view->cell.head,col,1.0);
    cellhd.rows = bottom-top+1;
    cellhd.cols = right-left+1;
    cellhd.ns_res = (cellhd.north-cellhd.south)/cellhd.rows;
    cellhd.ew_res = (cellhd.east-cellhd.west)/cellhd.cols;
/*fprintf(stderr,"\nnorth,south,east,west,nsres,ewres %f %f %f %f %f %f",
               cellhd.north,cellhd.south,cellhd.east,cellhd.west,
	       cellhd.ns_res, cellhd.ew_res);*/
 * Outline the zoom window on the main map
 * Turn previous one to grey.
    if (zoom_view->cell.configured)
	R_standard_color (GREY);
	Outline_cellhd (main_view, &zoom_view->cell.head);
    R_standard_color (RED);
    Outline_cellhd (main_view, &cellhd);
/* If a region is drawn in the zoom window erase it and the saved
   region, if any */
    if (Region.area.define && Region.view==VIEW_MAP1_ZOOM) {
      erase_region();
      if (Region.area.saved) {
	Region.saved_npoints = 0;
	Region.area.saved = 0;
	Region.saved_view = NULL;
 * zoom
    G_adjust_window_to_box (&cellhd, &zoom_view->cell.head, zoom_view->nrows, zoom_view->ncols);
    Configure_view (zoom_view, pick_view->cell.name, pick_view->cell.mapset,
	pick_view->cell.ns_res, pick_view->cell.ew_res);
    draw_cell (zoom_view,OVER_WRITE);
    return 1;	/* pop back */
static
cancel()
    return -1;
