I believe that if you select the compress option when you
exit v.digit the "dead lines" are removed from the dig_att
file when v.clean is run.
James A. Farley Technical Director, CAST/NCRI-SW
12 Ozark Hall, Univ. of Arkansas
jim at moray.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
