No subject
bens at chelsea.cee.Wisc.EDU
Wed Jun 3 13:05:02 EDT 1992
I am trying to join together six soil maps (vector format, township
size) using GRASS. The maps have a township line that forms the
boundary for each of the soil maps. I tried v.patch and did spatially
join the maps together, but I lost the corresponding attribute
information (dig_cat file). I read in the manual under bugs that I
should run v.support. I ran v.support for building topology, but
still no attribute information. I then tried to run v.support for
edit the category file. However, I got the following message:
WARNING: category support for vector file missing. So, how do I join
together vector files and still maintain the corresponding attribute
information?
Second, is there a way to remove the township lines? I presume
I need to do this after the maps are joined, otherwise I lose soil
polygons around the edges.
I appreciate any thoughts you might have on this problem as I
am new to GRASS. For future reference, would I have been better off
to edgematch and join coverages in ARC/INFO and then bring them across?
Again, thanks.
Jan Benson at bens at chelsea.cee.wisc.edu
