How does 'd.rgb' work?
Dave Gerdes dpgerdes at zorro.cecer.army.mil
Tue Mar 3 18:29:42 EST 1992
> Date: Tue, 3 Mar 92 12:03:46 HST
> From: Jinn-Guey Lay  <jinn at uhunix.uhcc.Hawaii.Edu>
> To: grassu-list at amber.cecer.army.mil
> Subject: How does 'd.rgb' work?
> I was trying to display an elevation map in color with a shadow
> releif map in grey tone. I have tried 'd.his' using elevation
> as hue and shadow relief as intensity. It looks OK only if I stay
> far enough; the display is somehow noisy with many pixels of
> different colors scattering arround.
> I have also tried 'blend.sh' to combine elevation and shadow
> relief maps. What the 'blend.sh' script does is to grab the
> R,G,B values of each map separately, add them together, and
> store the added R,G,B values into three new raster files, i.e.
> file.r, file.g, and file.b. Following this, I tried 'd.rgb' command
> with the three raster files as input for red, green, and blue.
> The result does not look right. It does not hold the original colors
> of elevation and does not have any apparent pattern.
> So, how can I display a map using its RGB values?
> Does any netter have similar experience on these problem?
> Any advice on 'd.rgb', 'd.his', and map overlay will
> be appreciated.
> Jinn-Guey Lay
> GIS & Computer Cart. Lab
> University of Hawaii at Manoa
I think i.median is what you are looking for.  i.composite will also work
but the results will be different.  The output of i.median looks best
on a driver that supports full 256 color display in colormode float.
while I am on the subject, I have a new derivative of blend.sh called
intens.sh.   While blend.sh combines two colors into one, intens.sh
is designed to work with a color file, and a grayscale file, using the
grayscale to vary the intensity of the colors.  This avoids the
'washed out' effect of you can get from blend.sh
Also, if you have a Silicon Graphics, the latest version of SG3d (not
in distribution yet, but will be shown at GRASS User's Conference, I hope)
has full lighting model support, so all this stuff is no longer necessary.
The program intens.sh follows:
------------------------------ Rip Here ------------------------------------
#!/bin/sh -f
#  written by Dave Gerdes  Nov 1991
if [ $# != 4 ] ; then
    echo 'Usage: intens.sh file1 file2 perc outbase'
    echo ''
    echo 'This program is a derivative from blend.sh.  It is designed'
    echo 'for the special case when file2 is an aspect or other gray'
    echo 'scale map.  It avoids the washed out affect of combining'
    echo 'a gray scale map with another map, by using ONLY the colors'
    echo 'from the color map, and using the aspect file to vary only the'
    echo 'intensity creating 3 new files representing the R,G, and B'
    echo 'components of the resultant image.'
    echo ''
    echo 'The files will be named  outbase.r outbase.g outbase.b'
    echo 'and have data values in the range 0-255'
    exit 1
fi
first=$1
second=$2
perc=$3
out=$4
if [ $perc -eq 100 ]
then
  perc=1.0
else
  perc=.$perc
fi
for i in r g b
do
    r.mapcalc << ____EOF
	$out.$i = eval ( \
	first = $i#$first, \
	second = $i#$second, \
	range = first * $perc, \
	base = first *  (1. - $perc), \
	gray = second / 255., \
	res = range * gray + base, \
	if (res > 255, 255, if (res < 0, 0, res)) )
____EOF
done
exit 0
------------------------------ Rip Here Too --------------------------------
  Dave Gerdes
  US Army Construction Engineering Research Lab
  Spatial Analysis & Systems Team
  dpgerdes at cerl.cecer.army.mil
  (217) 352-6511 x591
