s.surf.idw
Chris Skelly chris at mqatmos.cic.mq.edu.au
Tue Mar 24 11:30:47 EST 1992
>> The continue stmt in question is in a loop. It prevents the code which folows
>> from being executed. I could have used and if-else, but I prefer this
>> semantic when I can use it.
>> Michael
>but the "continue;" is in an "if" statement not a loop...the interpolation
>routines are outside this "if" statement so doesn't the continue just
>jump out of the if and do the interpolation?  I'm not myself if this is
>a serious question, because I have used s.surf.idw and it works...unless
>there are actually values under the mask...I have never checked...
>chris
Well actually, I am MYSELF....just a little confused folks...
  I'm not sure, myself....  <-- this is the correct babble...
chris (i'm sure...)
