RIM question
Hendrik K. Meij meij at pop.psu.edu
Thu Nov 12 10:14:32 EST 1992
> ld: file /mnt/grass/grass4.0/src.related/rim/LIB/librim.a cannot be opened
> ld: (Warning) did not generate an output file
> *** Error code 1
It appears to me you are compiling RIM in src.garden. You first must compile
the RIM source in src.related/rim in order to create the shared libraries
used later. The makefile is not to clear about the following either: there is
no make all. So, read the README file and do all individual steps( I think
they are make rim, make rime, make lxtest, make help). You will hit another
error on make man I believe or make help. Reverse the order, I think you
need to make help as the last step. Do not forget make install.
I could look into my log files if this does not solve your problems...
Groetjes,
-Henk
  * * * * * * * *   Hendrik K. Meij
  * Penn  State *
  *             *   The Population Research Institute - Penn State University
  *   1 8 5 5   *   ---------------------------------------------------------
  *             *   meij at pop.psu.edu                             814-863-7375
     *       *      22 Burrowes Building
         *          University Park, PA 16802
