Grass 4.0 build on RS6000 problem
Duc Nygen duc at comsearch.com
Mon Nov 30 11:50:46 EST 1992
I built grass4.0 on an ibm rs6000 using gcc 2.3.1 without much of a problem
(main problem was K&R C variants), and tried to start X window driver and
go the following errors:
GRASS-GRID > d.mon
                    MONITOR MENU
Making sure that the graphics monitor is running
     1 - start a graphics monitor
     2 - stop a graphics monitor
Choosing a graphics monitor for your graphics
     3 - select a graphics device for output
RETURN - quit
> 1
Enter name of graphics monitor to start
Enter "list" for a list of known monitors
Enter "list -f" for a list with current status
Hit RETURN to return to menu
> x0
longjmp or siglongjmp function used outside of saved context
bsh: 13966 Abort: A memory image file is created as "core".
Please start graphics monitor <x0>.
Error - Graphics monitor <x0> not running!
Problem selecting x0. Will try once more
hit RETURN ->
Help!
thanks
