Linux/Grass
Kuo-Chen Chang
harry at atlas.socsci.umn.edu
Fri Oct 2 14:11:58 EDT 1992
> I am intereseted in hearing from anybody who has done some work with Grass and Linux.
> Linux is a version of Unix that is public domain and has been written for the Pc386
> platform. X11v5 has been ported to Linux already. It would seem that it would be
> a good choice to port Grass to as both are public domain, thus keeping with the
> low cost GIS idea.
> Regards,
> Rob Linton
> Charles Sturt University - Murray,
> Australia.
> Net: rlinton at csu.edu.au
i posted the same Q a month ago and received nothing.
harry
reading this).
As a side note, this will make the digitizer interface greatly
modifiable by the user, so any number of formats can and should be
supported. Also many digitizers can be re-programmed by the software,
and thus we might just be able to get around this problem of being
incompatible with AutoCad or ArcInfo requirements, and having to flip
switches.
Here is our sample file for the Calcomp 9500 Ascii mode 5
setup
buttons = 16
buttonstart = 0
baud = 9600
units_per_inch = 1000
start
send = \027%^5\013 # ESC%^5 Force into mode 5
send = \027%R\013 # ESC$R Set RUN mode
send = \027%Q!\013 # ESC%Q! Set query char to '!'
query
send = !\013 # ! Query digitizer
stop
send = \027%H\013 # ESC%H Halt RUN mode
format
# format is ASCII 5 chars X, 5 chars Y
# and button status is in 15th column
ascii = xxxxx,yyyyy,??b
The format definition for Binary mode 23 is simply:
format
byte1 = 1 p b3 b2 b1 b0 x15 x14
byte2 = 0 x13 x12 x11 x10 x9 x8 x7
byte3 = 0 x6 x5 x4 x3 x2 x1 x0
byte4 = 0 ? ? ? x16 y16 y15 y14
byte5 = 0 y13 y12 y11 y10 y9 y8 y7
byte6 = 0 y6 y5 y4 y3 y2 y1 y0
Coming attractions: Look for Xdigit in 1993.
Dave Gerdes
US Army Construction Engineering Research Lab
Spatial Analysis & Systems Team
dpgerdes at cecer.army.mil
(217) 352-6511 x591
