Extracting SPOTView images.
Michael Shapiro
shapiro at zorro.cecer.army.mil
Mon Oct 5 10:15:11 EDT 1992
(1) Current design requires extraction to an xy location. It does not
require rectification before you use the image. You may do
classifications on the raw image and then rectify those. Rectifying
before and then running analysis gives you a more complete access to
the gis layers whcih relate to the image (vector and raster) but comes
with the cost of resampling your image.
(2) If you really want to extract directly into UTM location and have
data already georeferenced you could do one of two things:
(a) extract into an xy location and use unix commands to move all the
data (raster as well as group) into the UTM location;
(b) Remove the I_must_be_imagery_projection() call from the programs
which extract images and this will allow you to put images directly
into whatever location you wish. Be warned that the extraction
utilities (with perhaps the exception of i.tape.other) may not know
about rectified imagery.
Note: you will have to run r.support to create a proper header for the
images
|Question 1:
| Do we always extract the SPOT images from 1/2" tape (SPOTView) into an (x,y)
|location and then rectify it ? I'll probably call the company on Monday but in the
|mean time it would be great if some one can clarify this.
|Question 2:
| Is there anyway one can buy a rectified image and then extract the image
|from the tape into an UTM location ?
|Thankyou,
|Laxmi P. Musunur (LP)
Michael Shapiro U.S. Army CERL
email: shapiro at zorro.cecer.army.mil Environmental Division
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
