How to create ppm-files of a p.map-ouput ?
Carlo van de Rijt
carlor at sci.kun.nl
Wed Oct 14 10:55:19 EDT 1992
> Hello,
> how can I pipe the p.map-output in a ppm-file ?
> Or better: How can print out a GRASS-map on a printer like the
> HP PaintJet or simply the LaserJet ?
> Bye
> Andreas Wytzisk
Here we use the ppm driver to create ppm output. This output
is converted to pgm by a program called ppmtopgm. A program
called pgmtops is used to convert this format to postscript.
pgmtops and ppmtopgm are available on different anonymous ftp
sites. Try using 'archie' to find them.
Carlo van de Rijt
Dept. of Ecology
University of Nijmegen
The Netherlands
Tel. ++31-80653047
Fax. ++31-80553450
