small islands, how to eliminate?
    Lars Schylberg
    larss at fmi.kth.se
    Fri Oct 23 03:32:55 EDT 1992
> Does anyone know a method to remove single pixel islands either in cell map
> or vector map
> ? I'm trying to export a grass file to arc.info and need fewer than 10,000
> polygons for it to work.
> Thanks,
> Mary Ingham
> mingham at grits.valdosta.peachnet.edu
I been looking at this problems for some time.  I presented some of my
results at the European Grass Users Conference this year.
Unfortunally I haven't had any time write it in a paper yet.  But here
is the most simple solution.  If you want to remove single pixel
islands you could remove those with a mode filter operation.  Here is
one method to do this:
1. run r.clump and r.stats to detect which areas that only are on pixel islands
2  reclass all those areas to zero
3  run r.neighbors with the mode filter to fill those zero areas with the
   most frequent neighbors.
   You could also create a mask that protects all other areas to be
affected by the mode filter operation except for the zero holes.  This
solution assumes that you have a map this is all non-zero values, otherwise
these have to be save with a reclass before you perform this operation.
If you want to do more advanced solutions I have a new mode
function that can be used in r.mapcalc if want to remove a slightly larger
pixel island.  This gives an opportunity to create different shapes on
the mode filter kernel with the neighborhood facilities in r.mapcalc.
I don't remember but I think I sent this mode filter fuction to grassp once.
Good luck.
Lars
Lars Schylberg                    Email: larss at fmi.kth.se
Department of Photogrammetry
Royal Institute of Technology     Tel.   +46 8 790 86 33
S-100 44  STOCKHOLM, SWEDEN       Fax.   +46 8 790 66 10
