24 Bit X-terminal error
Don Baird baird at bml4380.cpg.cdc.com
Mon Oct 26 11:07:38 EST 1992
We recently tried to run GRASS on a ShoGraphics X-terminal, model PS1.  This
is a 24 bit color device.  We received the following error message when
the d.mon command was executed:
>    Graphics driver [x0] started
>    Please start graphics monitor <x0>.
>    X Error of failed request:  BadMatch (invalid parameter attributes)
>      Major opcode of failed request:  78 (X_CreateColormap)
>      Minor opcode of failed request:  0
>      Resource id in failed request:  0x27
>      Serial number of failed request:  225
>      Current serial number in output stream:  226
>    Error - Graphics monitor <x0> not running!
>    Problem selecting x0. Will try once more
Any ideas?
   C O N T R O L   |           Control Data Systems, Inc.            |
     ___   ___     | Donald R. Baird           baird at dsr.cpg.cdc.com |
    / __|  __ \    | St. Louis, MO                      314-872-2237 |
   ( (__   __) )   |                              FAX - 314-872-2206 |
    \___  |___/    +- - - - - - - - - - - - - - - - - - - - - - - - -+
                   | "It's much easier to apologize than get per-    |
      D A T A      |  mission."    -    Adml. Grace Hopper           |
