Postscript and plotter files
Michael Shapiro
shapiro at zorro.cecer.army.mil
Tue Oct 27 11:29:20 EST 1992
I don't know the answer for mapgen, but they the way you get
PostScript from p.map is to select the "ppm" driver and then run
p.map. This will create a "paint.ppm" file in your HOME
directory. You must then use other filters/tools to convert this
file to postscript. You can use the pbmplus software (distributed
with grass, but not automatically compiled). pbmplus converts
between numerous raster formats and it has its own formats as
well. One of theses format is "ppm" (portable pix map) and there
is a program among the suite of pbmplus tools which converts ppm
files to postcript files. (It used to be called ppmtops, but I
think now it is pnmtops - you'll have to read the documenation on
pbmplus). The paint.ppm file is in the "ppm" format understood by
the pbmplus software.
There will be some new "p.map" like tools called ps.map to be
released with 4.1 that will create postscript output directly.
|Where in the GRASS documentation is there mention of generating PostScript
|and stand-alone plotter files with either p.map or mapgen?
Michael Shapiro U.S. Army CERL
email: shapiro at zorro.cecer.army.mil Environmental Division
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
SpellingList
CERL
P.O
PostScript
