Problems with starting monitors
Laxmi Prasad Musunur
mlp at forestry.auburn.edu
Fri Sep 4 16:44:05 EDT 1992
>From: ngaur at chief.ecn.uoknor.edu
>I am sorry for not letting you knoew about the error messages I
>got, Here they are:
>Graphics driver [x0] started
>Graph_Set: can't open
>Please start graphics monitor <x0>
>Error - Graphics monitor <x0> not running!
>Problem selecting x0. Will try once more
>Please start graphics mionitor <x0>.
>Error - Graphics monitor <x)> not running!
The two things that you need to do are:
Make sure you add RISC as an xhost on DEC Station. i.e. on DEC type
xhost +YOUR_RISC_HOST_NAME
In c-shell you can set the DISPLAY variable on RISC before running grass i.e. on RISC type
setenv DISPLAY YOUR_DEC_HOST_NAME:0.0
Then invoke grass on RISC.
Hope that helps,
LP
