GRASS FTP site
    hoffmann at urzdfn.kartographie.tu-dresden.dbp.de
    Fri Sep 18 09:59:30 EDT 1992
I confirm the troubles others have had too. Your **new** <MOON> didn't
recognice the "ls -l" command but "ls" did work normally...
That isn't the problem of our servers or OS etc.
The **old** <MOON> and the **older** <AMBER> worked very well!
BTW, we are working under UTek-V on TEK-88/34 and got the GRASS from <AMBER>.
F. Hoffmann, TU Dresden, Germany
rom lists-owner at max.cecer.army.mil  Fri Sep 18 09:00:32 1992
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
	id AA00366; Fri, 18 Sep 92 09:00:32 CDT
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA01075
  (5.67a/IDA-1.4.4 for <grassu-people at amber.cecer.army.mil>); Fri, 18 Sep 1992 09:00:29 -0500
Return-Path: <courtney at agcrr.bio.ns.ca>
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
	id AA00360; Fri, 18 Sep 92 09:00:17 CDT
Received: from agcrr.BIO.ns.ca by max.cecer.army.mil with SMTP id AA19628
  (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Fri, 18 Sep 1992 09:00:13 -0500
Received: by agcrr.bio.ns.ca (5.57/Ultrix3.0-C)
	id AA02970; Fri, 18 Sep 92 11:01:03 -0300
Date: Fri, 18 Sep 92 11:01:03 -0300
Message-Id: <9209181401.AA02970 at agcrr.bio.ns.ca>
Sender: lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Precedence: Bulk
Subject: re: r.in.sunrast AGAIN
Cc: courtney at agcrr.bio.ns.ca
Helpful suggestions for the fix to r.in.sunrast have been offered
by :
Jim Hinthorne,
Director GIS Lab
Central Wash. Univ.
He pointed out that :
Two more changes are needed to make this program bullit-pruff.
1.  The parameter passed to G_malloc should be ncol_fix, not ncols,
because this is the size of the record to read later.
2.  Before the final "return 1;" there should be "free (raster);" so
that the space allocated by G_malloc will be freed up.  Some systems
are good about doing this automatically when the program exits, but
some aren't so friendly and the programmer should take responsibility
for freeing allocated memory.
So, the new fix to r.in.sunrast would be :
cd src.alpha/raster/r.in.sunrast/cmd
and edit main.c
replace the function rasttocell with :
rasttocell (rast_fd, cell_fd, nrows, ncols)
    unsigned char *raster;
    CELL *cell;
    int row, col, ncol_fix ;
    /* check if row is even or odd */
    ncol_fix = ncols;
    if ( ncols % 2 )
           ncol_fix += 1 ;
    cell = G_allocate_cell_buf();
    /* JH fix 1 */
    raster = (unsigned char *) G_malloc(ncol_fix);
    if (verbose)
        fprintf (stderr, "complete ... ");
    for (row = 0; row < nrows; row++)
        if (verbose)
            G_percent (row, nrows, 2);
        if (read (rast_fd, raster, ncol_fix) != ncol_fix)
            return -1;
        for (col = 0; col < ncols; col++)
            cell[col] = (CELL) raster[col];
        if (G_put_map_row (cell_fd, cell) < 0)
            exit(1);
    if (verbose)
    /* JH Fix 2 */
    free (raster);
    return 1;
and recompile
Thanks, Jim
Bob Courtney
Atlantic Geoscience Centre
