Xgen sliders
John Cartwright johncc at picea.CFNR.ColoState.EDU
Sat Sep 19 00:50:01 EDT 1992
Hello all,
I'm having a problem with xgen that is driving me to distraction (although xgen
itself is really an incredible piece of software!).  Anyway the problem comes in
trying to use the slider object and retireve the value that is set.  As far as I
can tell from the documentation, the script listed below should work, but
unfortuantely, the "accept" button causes the program to behave erratically and
finally to crash with a segmentation fault.
The real issue for me is retrieving the value set by the slider and storing it
in a shell variable for use in a command line argument and for later use in the
xgen script.  Any help or suggestions would greatly appreciated.
John Cartwright
johncc at picea.cfnr.colostate.edu
/* XGEN script to receive user input via text entry and slider object.
#define DarkFG  foreground:NavajoWhite
#define LightBG background:black
#define DarkBG  background:NavajoWhite
#define LightFG foreground:black
DarkBG
LightFG
font:"*adobe*helv*r*normal*14*"
/* beginning of the first environment...  */
environment firstEnv
	initialshells:"Main"
	commandboard Main
		titlestring:"Main Window"
		x:0
		y:0
		background:IndianRed
		setOPTIONS:""
		setWSHD_DESCRIPT:""
		setFILE_NAME:""
		setMAP_PREFIX:""
		separator I1
		       separatortype:singleline
			x:0 y:50 width:500
		label "Enter Watershed Description"
			alignment:center
			x:0 y:75
			width: 500
		textentry t2
			x:0 y:100
			width:500
                slider rain
                        titlestring:"Set Rainfall Amount in Inches"
                        font:"*adobe*helv*med*r*normal*14*"
                        x:0 y:150 foreground:black background:IndianRed
			decimalpoints:0
			orientation:horizontal
			startvalue:0
			minimum:0 maximum:50
                button "Accept"
			x:0 y:300 width:250 alignment:center
			height:60 popdown:Main popup:showResults
		button "QUIT"
			x:0 y:400 width:250 alignment:center
			foreground:IndianRed height:60 popdown:Main
			exit:0
	commandboard showResults
	setRESULT:"[rain]"
		label "Results Summary"
		x:0 y:0 width:350
		label "rainfall amount = "
		x:0 y:75 width:50
		label value
		x:50 y:75 titlestring:"$RESULT"
		font:"*adobe*helv*bold*r*norm*14*"
		alignment:center
		separator a1
		separatortype:doubledashedline
		button "OK"
		x:0 y:150
		popdown:showResults popup:Main
