GRASS FTP site
Sincak KUKO at CSPUNI12.BITNET
Sat Sep 19 15:50:05 EDT 1992
On Fri, 18 Sep 92 07:07:45 CDT <Russ=Northrup%IMS%USACERL at aardvark.cecer.army.mi
>Hi!
>  I cannot reproduce the FTP error some of you are describing using any of
>our local machines, even PC's.  Thus I would like to request the following
>information from anyone experiencing FTP problems.
>	1)  Brand name and model of machine the fault occured on.
------- IBM 3090 Ip 147.32.1.2 or Sun Sparc2 192.108.131.11
>	2)  Brand name of the OS on that machine. (ie SCO, EP/IX, etc)
      CMS (ibm 3090) SUN OS 4.1 (Sun)
>	3)  Version number of that OS you are using.
>	4)  Whether problems persist when you disable the advanced
>	    features of our FTP.  (ie send "-" as the first char of
>	    your password)
 "-" goes fine ; the only problem is "ls -l" command
     but "ls" command goes fine so the server is useable
     it is not too bad :-) .
>Maybe I can find a common thread among your responses.
>Thank you,
>Russ Northrup
>Systems Admin, US Army CERL
Peter Sincak , KUKO at cspuni12.bitnet
