polygons that share a common boundry(?)
Josef Fuerst fuerst at donau.boku.ac.at
Thu Sep 24 10:15:26 EDT 1992
> Lets say you have two areas separated by a single line:
>         ____________________
>         |  1    |    2     |
> I brought these areas in to Grass via v.in.dxf, I now want to convert tis
> into two labled areas without having to digitize the polygons in v.digit.
> If this can't be done in Grass directly, does anyone know if Arc/Info can
> do it?
ARC/INFO certainly can do it. It has a DXFARC import, and then you must
BUILD cover POLY to get a clean polygon topology.
J. Fuerst
Internet: fuerst at donau.boku.ac.at
