is ps.map working?
James A. Farley jim at cast.uark.edu
Thu Apr 1 10:13:48 EST 1993
> I have had no luck getting ps.map to run, though it compiled successfully
> (including ps.icons) on a DECStation 5000.  On the DEC (Ultrix 4.2a), I can
> play 20 questions with ps.map just fine, but when I commit, I get:
> set the printer and hit RETURN -->
> pid 21542 (ps.map) was killed on a kernel access, at pc 0x40f174
> Bus error
> On the Sun 1+ (SunOS 4.1.1), I get an unceremonious Segmentation fault.
> This is using the downloaded Sun binaries, not a locally compiled version.
> Any ideas???
> -kenn
Make sure that the postscript device description file (ps.devices)
is built and locatied in $GISBASE/etc/paint. See the man page for
ps.select for a discussion.
James A. Farley 	Technical Director, CAST/NCRI-SW
			12 Ozark Hall, Univ. of Arkansas
jim at cast.uark.edu	Fayetteville, AR  72701
Voice: (501) 575-6159	FAX  : (501) 575-3846
