Problem starting monitor
hoffmann at urzdfn.kartographie.tu-dresden.dbp.de
Tue Apr 6 08:03:29 EDT 1993
Try it interactively to start (1) und to select for output (3), usually
G40 should start AND select automatically, but I got also such errors when
have getting started from remote (SGI winterm) to the host machine (TEK).
And... use the right command syntax!
> d.mon help gives a short help message
> d.mon will ask you interactively
> d.mon start=x0 select=x0
Frank Hoffmann
