xgen
Paul Loechl
loechl at zorro.cecer.army.mil
Fri Apr 23 14:15:16 EDT 1993
In an E-mail message, Teresa Hansen wrote:
> Hi all you xgen user's (and creators - Kurt)
> I have written an xgen script, and now I want to modify some of
> the pulldown menus. Presently on the menus there is a label a
> static button and a dynamic button. When this menu is in view
> there is a scroll bar at the right side. When using the scroll-
> ing device the label and static button scroll up, out of view of
> the menu. This is not a great problem, mostly a peculiarity to
> my users who would like to see the label and static button remain
> in view at all times, while still being able to scroll through the
> other items lited (in the dynamic buttons). Does anyone have a
> solution to this?
> Teresa Hansen
> lewis!teresa at cerl.cecer.army.mil
> 206-967-5337
> Thankyou!
In order to prevent the labels and static buttons from scrolling out of view
when you use the scroll bar, you should use the xgen tool called "list".
There are several types of lists:
Single (listtype:single) One selection at a time by clicking with the
mouse.
Multiple (listtype:multiple) Several picks allowed by clicking with the
left mouse button. All selections remain highlighted.
Extended (listtype:extended) Several picks allowed by holding mouse
button down and dragging. All selections remain highlighted.
Browse (listtype:browse) Similar to extended except that only one
file is highlighted at a time.
The following xgen script can be used as an example:
#define cent alignment:center
#define back background:white
#define fore foreground:white
environment start
initialshells:"One"
sethome:"!cd"
commandboard One
x:800 y:100
label "This is an Example"
x:0 y:0 cent back ;
button abc
titlestring:"Exit"
x:0 y:30 width:100 fore cent
exit:0 ;
list reporter
x:0 y:70
updatefrom:"!ls $home"
visibleitems:11
listtype:single
listseparator:"," ;
/* The button below is only an example */
button "Select"
x:0 y:280 width:80 alignment:center
setFILE:"[reporter]"
runforeground:"cd $LOCATION/paint; if test \"[reporter]\"; then echo 'vector [reporter]' >> $FILENAME; fi"
popdown:One
popup:Something ;
________________________
Paul Loechl loechl at zorro.cecer.army.mil
USA CERL 1800-USA-CERLx668
