attributes to categories
Doug Hersh
dhersh at lupine.mbl.edu
Wed Apr 28 15:16:13 EDT 1993
I have some files in dig format which are simply maps with several
polygons within a circle. Each polygon has an attribute in a dig_att
file under the same name as the dig map. These attributes are integer codes
for a vegetation mix. I would like to rasterize these maps so that the
attributes become the category value in the raster map. Then I want to
reclassify the categories based on values in a lookup table.
I thought that when running v.to.rast I would end up with a raster
map with the categories taken from my attribute file, but the cat file
looks like this:
GRASS 4.0 > more 3c1981.0
# 373 categories
0.00 0.00 0.00 0.00
0:no data
Can anyone outline the steps I need to take to get a raster file
with the correct category values. I have no labels for the categories
because the categories themselves are numerically important.
Thanks,
________________________________________________________________
Doug Hersh Boston University Marine Program
dhersh at lupine.mbl.edu Marine Biological Laboratory
(508)548-3705 ext. 516 Woods Hole, MA 02543
