"Map registration in LT-PLUS"
Michael J. Paulick
mpaulick at force1.utsi.edu
Mon Aug 2 14:38:22 EDT 1993
I am trying to register a map using LT-PLUS. The corners of the map are
not known locations. The only known locations are within the map itself.
The register command asks for corner identifiers. Does anyone know how to
register a map without using the corners?
Mike Paulick
----- End Included Message -----
Dear Sir:
What is LT-PLUS?
If you are registering a map by using GRASS, you need at least four points, not necessary the corner points, to do it.
John Wu
