r.in.erdas help
Eric Lambert lambert at gis.uiuc.edu
Thu Dec 2 10:03:48 EST 1993
Xin,
You might want to give "i.in.erdas" a try. I was ahving trouble with the "r.in.erdas" too.  I think that the r.in version might work better on .gis extension files.  Once I gave the i.in version a try, it worked just fine.
Good Luck.
-Eric
Eric Lambert					Lab: (217) 333-5919
Illinois Natural History Survey
607 E. Peabody Drive
Champaign, IL 61802
E-mail:lambert at murphy.gis.uiuc.edu
<> From grass-lists-owner at max.cecer.army.mil Wed Dec  1 17:24:06 1993
<> Date: Wed, 1 Dec 1993 18:20:17 -0500
<> From: Xin Zhuang <zhuang at access.digex.net>
<> Sender: grass-lists-owner at max.cecer.army.mil
<> Reply-To: grassu-list at max.cecer.army.mil
<> To: grassu-list at max.cecer.army.mil
<> Subject: r.in.erdas help
<> Content-Length: 504
<> I did "r.in.erdas erdas=tm083090.lan prefix=tm"
<> and took all 7 bands. I got tm.1 ... tm.7.
<> I run r.support to all of them and greated a group (tm90).
<> I was trying to run i.composite but failed. I was told
<> one of files was out of range which cannot be true.
<> I r.compress-ed tm.3 and wanted to look at it.
<> What I got were a whole bunch of vertical lines.
<> All the info in cellhd seem correct and match
<> the ERDAS file header (version 7.5).
<> Any hint would be appreciated.
<> --Xin
<> zhuang at access.digex.com
