Importing Elevation data from an ASCII format
Brian Culpepper brian at cast.uark.edu
Thu Dec 9 16:39:17 EST 1993
Tom Nelson writes:>
> with a sites file then do either s.surf.idw or s.surf.tps.
> Both create a surface file but tps takes a lot longer and with possibly better results.
> then r.contour which produces a vector contour map of interpolated contours from the
> surface file.
I will have to disagree with "do either s.surf.idw or s.surf.tps". These two
interpolation modules are NOT the same! If you are creating an elevation surface
then I believe s.surf.tps is the one to use, because all "sites" are equally
weighted, whereas ".idw" refers to inverse distance weighting. The ".idw" could
create unsatisfactory results. I suggest testing these two modules on a sample
dataset and comparing results.
A good reference is Helena Mitasova article in the Spring 1993 GRASSCLIPPINGS.
Hope this helps...
R. Brian Culpepper                                 Research Assistant
Center for Advanced Spatial Technologies           (fax) 501 575-3846
Rm. 214 Ozark Hall                                (work) 501 575-6159
University of Arkansas                            brian at cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
