Help! No PERMANENT mapset
ye qi
qi at cdrgsun.UCSD.EDU
Wed Dec 22 12:04:19 EST 1993
Hi, Enrique:
I had that problem before. The reason for mine was I created a map location
using 'mkdir dir-name' before running GRASS. Why not you just try entering grass first (by typying grass4.1) then at 'LOCATION: spearfish_____ ', type over
spearfish with a name that has NOT been created as a directory under your
$DATABASE. This should solve your problem. Good luck.
Ye Qi
Scripps Institution of Oceanography
University of California, San Diego
La Jolla, CA 92093-0220
(619)-534-4232
qi at cdrgsun.ucsd.edu
