Print maps using SPARCprinter
Lars Schylberg
larss at fmi.kth.se
Thu Dec 23 04:38:31 EST 1993
As far as I remember there used to be a bug in the interactive version of
ps.map. I don't if it has been fixed. It is possible to run it with
command line arguments however. Here is a small script that I have used
to output simple raster maps. It shows the principle.
Happy Xmas to everyone !
Lars
#!/bin/sh
# ps.map.sh
# Script that run ps.map
# Author: Lars Schylberg ( larss at fmi.kth.se )
# Department of Photogrammetry
# Royal Inst. of Technolgy
# Stockholm, Sweden
# Date: 930216
# History of changes:
# Check if GRASS is running
test "$GISRC" || echo "GRASS is not running" || exit 2
# Evaluate arguments
if [ $# != 2 ]
then
echo
echo Usage: `basename $0`
echo ' rast=mapname '
echo ' scale=mapscale '
echo
exit 1
fi
# parse input arguments
for i do
case $i in
rast*)
RAST=`echo $i | sed s/rast=//` ;;
ra*)
RAST=`echo $i | sed s/ra=//` ;;
r*)
RAST=`echo $i | sed s/r=//` ;;
scale=*)
SCALE=`echo $i | sed s/scale=//` ;;
sc=*)
SCALE=`echo $i | sed s/sc=//` ;;
s=*)
SCALE=`echo $i | sed s/s=//` ;;
echo ""
echo "Unrecognized option: $i"
echo 'Options: rast=mapname '
echo
exit 1
esac
done
# Check the input arguments
eval `g.findfile element=cell file=$RAST`
if [ ! "$file" ] ; then
echo "$RAST - clump cell file not found"
exit 2
fi
if [ $SCALE -lt 100 -o $SCALE -gt 1000000 ]
then
echo "This scale factor seems strange: 1:$SCALE "
exit 2
fi
eval `g.findfile element=cell_misc file=$RAST`
echo "Map: $RAST" > comments.file
echo "" >> comments.file
cat $file/RULE.* >> comments.file
fi
echo "scale 1:$SCALE" > ps.map.input
echo "maploc 1.25 1.25" >> ps.map.input
echo "greyrast $RAST" >> ps.map.input
echo "colortable y" >> ps.map.input
echo "where 1.25 0" >> ps.map.input
echo "font Helvetica Bold" >> ps.map.input
echo "fontsize 10" >> ps.map.input
echo "end" >> ps.map.input
echo "comments comments.file" >> ps.map.input
echo "where 4.5 1.5" >> ps.map.input
echo "font Helvetica" >> ps.map.input
echo "color black" >> ps.map.input
echo "end " >> ps.map.input
ps.map input=ps.map.input output=$RAST.ps
rm -f ps.map.input comments.file
prf -trans $RAST.ps
rm -f $RAST.ps
