raster_to_vector
Bob Feeney
feeney at vinny.cecer.army.mil
Mon Feb 1 13:59:25 EST 1993
After running r.poly you have to run v.support, first (1) to
build topology and then second (2) to create category support.
In v.support (2) you have to designate how many categories are
needed so you have to know what the highest category value
of the raster file was. Enter this number and then hit ESC.
You now have to manually enter the category descriptors, if
you need to show more than just the category number. If you
have many categories it is best to run r.cats to list them
prior to running v.support.
You can copy a portion of a file by first using d.zoom to
designate the new "region" and then copying the file. It
should only copy that portion of the file.
If you have any more specific questions or run into any problems
you can e-mail or even call at (217) 373-4420 ext. 320.
Good Luck.
Bob
