ERDAS IMP^HORT
Xiaojun Li
xili at cast.uark.edu
Mon Feb 1 14:39:05 EST 1993
> Dear TGRASS Users,
> In my current research thises I'm working on a project using GRASS.
> My first problem is how to get a disk with GRASS 4.1 as soon as possible, can
> somebody help me to find that out and how much would that be?
> The second problem I've got is how to get ERDAS data into GRASS.
> IWe want to import an 8-bit-LAN LANDSAT file into GRASS from ERDAS VGA 7.5.
> The file is about 70MB and in the BSQ-format. Unfortunatlely I was not able to
> import it yet. I've tried all the suggestions with BLK-Files[D[D[D[D[D[D[D[D[D[D[C.BLK-Files from theise GRASSSS
> user list.
> We are using GRASS 4.0 on a DEC5000. Can somebody help me?
> Lars Flemming
> Student of Computing Science
> Technical University of Dresden
> Germany
> By the way does anybody know if GRASS 4.1 does support INFORMIX-BLOB-datatypes?
> How can I use those data in GRASS?
> I would be pleased to reseivceive your helpfull messages !!!
> Thanks in advance
> Lars
> C0=DE;A=DBP;P=TU-DRESDEN;OU=INFORMATK;OU=SERV1;S=FLEMMING
Hi, Lars:
First, you need to convert ERDAS (7.5) file into ERDAS (7.3) using
cvt73. Then you can use GRASS command r.in.erdas read the file.
Xiaojun Li
Center for Advanced Spatial Technology
Univ. of Arkansas, Fayetteville, AR 72701, USA
k
